I already had other Z to drive, so the '90 NA was my toy for a while.. so I could learn.. I did the Ford Truck Motor Mounts.. DO NOT LEAVE THE HOSE CLAMPS AT THE TOP OF THE T-BODY .. it will leave dents on the hood.. Damit.. Gives a little more room on the Side of the Engine.. About 35$ each I removed the Hot Start Fuel Pressure increase Sol on the Left Intake Mount.. cleans up the Side.. I left all the other Smog Stuff.. I'm in California.. Removed the Clutch Bleader Pipe on the Left Fender well.. Rewired the 'Power Wire' going back into the Fuseable Links to a SINGLE LARGER wire that goes to the battery.. Using Acid Rust Remover, I cleaned and Painted the Battery Tray, and rmoved all the 'Road Trash' that collects under it and the Power Brake Area.. Cj
